Organize Panel
Use the Organize panel to (re)organize your database by copying or moving data (entities) among collectors, includes, or parts.
Collectors Subpanel
| Option | Action |
| entity switch | Select an entity type
                                    to copy/move, then use the selector to select specific entities
                                    to copy/move. The current collector serves as the default
                                    destination.
| dest component /dest group | Choose a collector to
                                    move the selected entities into.  When the entity switch is set to elems, choose between components or groups.  |
| face angle / individual selection |
Includes Subpanel
| Option | Action |
| (entity switch) | Use the switch to
                                    select an entity type to move, then use the selector to select
                                    specific entities to move into the include.  When you select
                                        nodes or elems, click the switch to change the selection mode.
| dest | Select an include to move the selected entities into. |
| move (nodes, elements, systems, vectors, loads and equations, beamsections) | Move additional
                                    entities (nodes, elements, systems, vectors, loads and
                                    equations, or beamsections) along with the selected parent
                                    collector.  By default this checkbox is selected. If cleared,
                                        the above entities may not be moved with the selected parent
                                        collector.
Note: Available when the entity selector is set
                                            to system collectors, vector collectors, load
                                            collectors, beamsection collectors, group, and
                                            components.
| edge angle |
                                     Split edges that belong to a given face. When the edge
                angle is 180 degrees, edges are the continuous boundaries of faces. For smaller
                values, these same boundary edges are split wherever the angle between segments
                exceeds the specified value. A segment is the edge of a single element.
                                Important: Only available when the entity selector is set to nodes and the
                    selection mode is set to free edges, free edges ext, edges, or edges
                ext.
Parts Subpanel
| Option | Action |
| entity switch | Select components to move. |
| dest module | Select a part to move the selected components into. |
Command Buttons
| Button | Action |
| move | Move the selected entities to the specified collector, include file, or module. |
| copy | Copy the selected
                                    entities to the specified collector, so that they exist in both
                                    the original and new collectors.  Entities cannot be copied to an include file or modules.  |
| reject | Undo the most recent copy or move operation. |
| locate | Query the database to
                                    determine to which include an entity belongs.  To use this option, click locate and then select an entity from the modeling window. The dest field displays the include to which the selected entity belongs.  |
| return | Exit the panel. |
