Adding Attachments
Each system and assembly has a list of attachments that connect it to other systems or assemblies. These are listed on the Attachments tab. You can modify an attachment by highlighting it in the Attachments list and using the entity collector to the right of the list.
Tip:
        - To specify a tag for the attachment, click in the Attachment Tag field and enter a tag string.
 - Delete an attachment by selecting it from the list and clicking Delete.
 - Modify an attachment's properties by selecting it from the list and clicking Edit.
