A report template can be imported from an XML file to reuse in the current POSTFEKO session.
On the Reporting tab, in the
Reports group, click the Import / Export template icon. From the drop-down list select the Import report template (*.xml) icon.
Figure 1. The Import report template dialog.
In the File name field, browse for the XML file to
import.
Click OK to import the XML file and to close the
dialog.
