Apply a magnetic dipole that can be either an electric ring current or a magnetic
line current that represents an elementary dipole element with a specified orientation,
magnitude and phase.
On the Source/Load tab, in the
Ideal Source group, click the Magnetic Dipole Source icon.
Figure 1. The Create Magnetic Dipole Source
dialog.
Specify the magnitude of the source using one of the following:
To specify the magnitude as the product of the loop current and loop
area, click Electric ring current.
In the Magnitude of IA (Am^2) field, specify
the current in Am2.
To specify the magnitude as the product of the dipole length and
magnetic current, click Magnetic line current.
In the Magnitude of Iml (Vm) field, specify
the voltage in Vm.
In the Phase (degrees) field, specify the phase of the
current.
In the Position field, specify where the source is to be
placed.
In the Orientation field, specify the orientation of the
source.
In the Label field, add a unique label for the magnetic
dipole source.
Click the Create button to create the magnetic
dipole source and to close the dialog.
