RL-GO Settings
A number of optional settings are available when using ray launching geometrical optics (RL-GO) to solve parts of the model.
On the Solve/Run tab, in the
Solution Settings group, click the
Solver Settings icon. On the Solver Settings dialog, click the High
frequency tab.
- Decouple from MoM solutions
- This option ignores the RL-GO regions when calculating
the MoM currents. The runtime and memory will be less
compared to a fully coupled (default) solution. This option should be used with caution.
For example, the input impedance of a dipole antenna close to a dielectric sphere, where
the dipole is solved using the MoM and the sphere using
RL-GO, will (incorrectly) be the same as that of the
MoM dipole in free space. Tip: Use this option where the MoM and RL-GO regions are electrically far apart (for example an aircraft nose cone radome).
- Maximum number of ray interactions
- This option limits the number of ray interactions (reflection and diffraction combined). For example, if this parameter is set to 3, a ray can have three reflections, or two reflections and a transmission. If left empty, then the maximum number if ray interactions is determined automatically.
- Edge and wedge diffractions
- This option takes the diffraction on edges and wedges into account.
- Export ray data for post-processing to
- *.bof file (default)
- This option exports the rays during the RL-GO solution process to the .bof file for visualisation in POSTFEKO.
- *.ray file
solution process to a .ray file.
This text file can be used for custom post-processing.Note: Large .ray files are possible when the MoM and RL-GO solution have not been decoupled and the MoM region contains a large number of mesh elements.
- Adaptive ray launching settings
- This option allows you to control the density of the rays launched, as well as when to
stop tracing a ray based on the ray's decay.
- High (more rays): The ray density is high. Results take longer to obtain but with higher accuracy.
- Normal (default): The default ray density setting.
- Low (fewer rays): The ray density is low. Results are fast to
obtain but with lower accuracy.Tip: Start with Low (fewer rays) which uses the least computational resources. When the model appears to be performing as expected, use a higher setting.
- Fixed grid increments
- This option allows you to specify the angular or spatial resolution for ray launching.
The resolution is specified by means of the increments in the U direction and V direction for a parallel ray front
(plane wave source) or in the φ and ϑ
directions (sources other than plane waves). Though the run-time for a problem involving
RL-GO may be decreased using this option, it may
influence the accuracy of the solution.Note: Manual specification of the increments should only be used after the implications have been carefully considered.
