Running from the Command Line
To run EDEM OpenCL GPU from the command line, the simulator engine has to be specified with the flag “-E” followed by the corresponding engine number.
- 0 runs the CPU engine
- 1 runs the GPU Open CL engine
In addition, you can set the Device Index for the GPU.
| Device Index | GPU Device name |
| 0 | Nvidia Quadro GP100 |
| 1 | Nvidia GeForce GTX 1080 |
| 2 | Nvidia GeForce GTX 1080 |
To run using the Nvidia Quadro GP100 card the following command would be required:
edem.exe -c -i c:\processing\mysim.dem -E 1 -D 0
or to use the AMD Radeon Pro WX 9100 card the -D 1 flag would be required.
For Multi-GPU GPU you would add the indices of all GPU cards to the command line. For example, to run the simulation on GPU devices 0 and 1, as specified by the Device index, enter the following:
edem -c -i c:\processing\mysim.dem -E 1 -D 0+1
The flags from the CPU version of EDEM are still be valid in order to set number of CPU processors used in the factory domains (-p), real time to simulate (-r), data save interval (-w), Cell grid size for factory space and particle to particle contact search (-g) and Time Step used (-t).
For example, to run on the command line with the GPU engine using only one card enter the following:
edem.exe -console -i simulation_deck.dem -E 1 -D 0 -p 4 -r 2 -w 0.1 –g 4 -t 1e-6
For Multi-GPU you would add the indices of all GPU cards to the command line, as shown previously. For example, to run the simulation on GPU devices 0 and 1 enter the following:
edem.exe -console -i simulation_deck.dem -E 1 -D 0+1 -p 4 -r 2 -w 0.1 –g 4 -t 1e-6
For Multi-GPU, you can define the axis about which the domain is split between devices. An example of running a 2 GPU simulation via command line with a split in the Y axis is as follows:
edem.exe -console -i simulation_deck.dem -E 1 -D 0+1 --gpu-split Y -p 4 -r 2 -w 0.1 –g 4 -t 1e-6
