Using LDAPs
To use TLS/SSL encrypted communication between Panopticon Real Time and the LDAP directory, we need to make the following changes in configuration:
- Change the protocol in the LDAP URL to ldaps
- Change the port in the LDAP URL to an SSL enabled port, typically 636
- If the LDAP directory is configured with a self-signed certificate; the certificate needs to be imported into a TrustStore.
See an example of a Tomcat Realm using LDAPS below:
<Realm className="org.apache.catalina.realm.JNDIRealm"
connectionURL="ldaps://ldap-server:636"
connectionName="cn=admin,dc=test,dc=com"
connectionPassword="admin"
userPattern="uid={0},ou=users,dc=test,dc=com"
roleBase="ou=groups,dc=test,dc=com"
roleName="cn"
roleSearch="(uniqueMember={0})"
rolenested="true"
There are two options for trusting a self-signed LDAP certificate:
- Import the certificate into the JVM TrustStore
The JVM TrustStore is located at JAVA_HOME/lib/security/cacerts. Use the command below to add a new trusted certificate to the TrustStore:
keytool -import -alias ldap -keystore cacerts -trustcacerts -file ldap.crt -noprompt -storepass changeit
- Create an application TrustStore
- Import the chain certificate:
keytool -import -alias ldap -keystore ldaptruststore.jks -file ldap.crt -noprompt -storepass changeit
- Import the LDAP server certificate:
- Check the TrustStore.
keytool -list -keystore ldaptruststore.jks -storepass changeit
- Configure Tomcat to use the new TrustStore by editing setenv.bat/.sh:
- setenv.bat (Windows)
set JAVA_OPTS=%JAVA_OPTS% "-Djavax.net.ssl.trustStore=[path to ldaptruststore.jks]" "-Djavax.net.ssl.trustStorePassword=changeit"
- setenv.sh (Linux)
export JAVA_OPTS="$JAVA_OPTS -Djavax.net.ssl.trustStore=[path to ldaptruststore.jks]-Djavax.net.ssl.trustStorePassword=changeit”
With either approach, Tomcat need to be restarted for the changes to have effect.
