Setting the Transportation Protocol
In previous versions, you can control which transportation protocol the browser would use for subscriptions to the server by setting the value (WEBSOCKET or LONG_POLLING) in the client.data.load.transport  property in the Panopticon.properties file.
Starting with version 2020.2, you can instead edit workbook.json  and admin.json  in <AppData>/JavaScriptConfiguration/, where you add the section:
"dataLoading" : {
    "transport" : "websocket" or "long-polling"
After each change in the workbook.json and admin.json files, the Panopticon application must be restarted.
