JDBC Driver Installation
Install the relevant JDBC driver(s) on the system where you are running Tomcat and Panopticon Real Time. The exact installation procedure depends on the JDBC driver. Follow the instructions given by the provider of the JDBC driver and by the provider of your Java application server (for example Apache Tomcat). In almost every case, a JDBC driver is installed by placing one or several jar-files in the /lib/  folder of your Tomcat installation.
