Change Password Dialog
When configuring an export to a PDF file, use this dialog to specify the password that must be supplied to open the file or to change the permissions for it.
Options
Field |
Description |
Enter password |
Enter the password you want to assign to the PDF file. |
Confirm |
Confirm the password by entering it again. |
Save password as PDF export default |
Select if you want to use the specified password as the default password for all exported PDF files. |
OK |
Click to save changes you have made to the settings and close the dialog. |
Cancel |
Close the dialog without saving changes. |
Help |
Display this help topic. |
