Summary View
Summaries allow you to analyze your table data.
In Monarch Classic, Summary View allows you to work with summaries. From Summary View, you can also click Summary Design to create or edit summaries.
The Summary View interface has the following elements:
Element |
Description |
[ 1 ] Ribbon |
Displays all the tools you need to work with a report. Refer to the Summary View Ribbon Quick Reference. |
[ 2 ] Selector |
Allows you to search for and/or select a specific summary and perform other operations |
[ 3 ] Summary View |
Displays the currently-selected summary. |
Going to Summary View
If you are in a different view, do one of the following:
Select the Summary tab.
If several tabs are displayed on the selector panel, select the Summary View tab.
Selecting a summary definition
To select a summary definition, click the summary on the Summary Definitions selector:
If you wish to search for a summary first, enter search criteria into the search box at the top of the summary definitions selector.
The Summary selector context menu
Right-clicking on the Summary selector displays a context menu that will allow you to perform the following operations:
Perform a quick export - This export operation uses the default file extension and values specified in Export Settings and presents the Create Export dialog with all elements prefilled
Rename a summary
Edit a summary (via the Summary Design interface)
Rebuild a summary (if a specific summary is selected) - This operation refreshes all input sources and recalculates the summary
Rebuild all summaries - This operation refreshes all input sources and recalculates all summaries
Quick print a summary
Move a summary to the top of the selector
Move a summary up one position
Move a summary down one position
Move a summary to the bottom of the selector
The Summary View context menu
Right-clicking in Summary view displays a context menu that will allow you to:
Copy text
With headers
Without headers
Copy with formatting
With headers
Without headers
Search for a record
Go to a specific row in the summary
Go to a specific column in the summary
Find a specific value in the table
Autosize columns
Adjust column widths
Display field properties
Set the active measure
Set a summary filter
Print the table
Launch Print Preview
Export the summary
Launch the Summary Design interface
Creating or editing a summary definition
Select Summary Design on the Summary View ribbon. The Summary Design interface displays.
Start creating your summary. See Creating a Summary for related information.
Additional Summary View actions
From within Report View, you can also do the following:
