Show Statistics
Displays statistics about a column. Statistics will show you, among others:
If your table has enough rows for you to work with
If there are nulls or blanks
The maximum, minimum, and average length of the values of the column
The number of unique values in the column
The sum of all values of a numeric column
Right-click on a column whose statistics you want to view.
Select Statistics > Show Statistics. The Statistics Panel displays.
To close to hide the Statistics Panel, select Hide Statistics
In this example, we've displayed the statistics for the column Customer:
A quick review shows that:
No records have null values
There are 64 rows in the table
There are 21 unique Zip Codes n the table
