The Browse for File Dialog
A standard Browse for FIle dialog allows you to select a source file on the cloud.
Select a Container.
Find the folder and then source you want to open. You may need to drill down several folders before you find your data source
Select the source and click OK.
Note:
If you are trying to browse the following sources:
Microsoft Azure Data Lake
Amazon S3
Oracle Cloud
Google Cloud Infrastrucure
IBM Cognos Analytics
Tableau Server
you need to first set the access credentials in the Server tab of Application Settings:
