Running a Maintenance Process
When a maintenance process runs, it executes all maintenance tasks assigned to it. When a maintenance process runs, it executes all log clearance tasks assigned to it. A maintenance process can be run in two ways:
Manually: To run a maintenance process manually
Click the
icon next to its name on the Maintenance Processes page or click the Run Now button at the bottom of the Maintenance Process page. You can do this immediately after configuring a new process, or you can manually run a previously configured process:-
click Report Warehouse, then click Maintenance Management on the Navigation Tree and select Maintenance Processes.
Click the name of the process you want to run.
Click the Run Now button at the bottom of the Maintenance Process page.
NOTE: When you click the Run Now button, there may be a brief delay before the process actually runs. This is likely due to a time discrepancy between the server's clock and the clock on a local machine. Processes are run according to the time of the server's clock.
Scheduled: To execute a maintenance process via a scheduled runtime
Specify the execution frequency for it on the Maintenance Process page, then click Save.
The process will be executed according to the scheduled execution frequency.
