Connector Dialog for Splunk
Enter values into the dialog box to connect and fetch data from your Splunk data source.
Options
Field
Host
The name of the machine or domain containing the data source. This machine must be accessible from the machine where Monarch Data Prep Studio is installed.
Port
Port Number required to access the data source.
Username
A valid Username required to log-on to Splunk.
Password
A valid Password required to log-on to Splunk. This password must match the Username above.
Connect
Click this button to connect to the Host after specifying the connection information above.
Select the Application for which you want to define a query.
Saved Search
Click on this radio button if a Search from a previous session is available. After selecting this button, select the search from the drop-down list.
Manual
Click on this button to execute a manual search operation. You will need to type in a valid Splunk search query into the Search Query box.
Search Query
Allows you to load, and then select, the tables from your database by entering a SQL Statement.
Enter the complete SQL Statement to select the tables and columns.
If you selected Tables and Views, this box is updated to show the corresponding  SELECT * FROM TABLE query.
Preview Data
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data.
OK/CANCEL
Select OK to establish the connection and fetch data or Cancel to close the dialog.
The state of the OK and PREVIEW buttons provide a handy status about the state of your connection:
  • The OK and PREVIEW DATA buttons are enabled as soon as the required fields have been entered and verified. This usually means a connection to the data source has been established and a table has been selected.
  • The OK button is disabled when an update is made that can lead to an invalid result (e.g. the User Name or Password is not valid, or the the SQL statement in the Query tab is invalid). In such cases, use  PREVIEW DATA to validate that data can be retrieved. If this fails verify your connection information or query until data can be retrieved.
Note:
When you select an Application, a blank name may sometimes display:
Select this blank name to display the saved searches for the default application, as defined in the Splunk User Profile.
