Connector Dialog for MongoDB
Enter values into the dialog box to connect and fetch data from your MongoDB data source.
Options
Field |
Description |
URL |
URL to connect to the MongoDB data source. |
IP Version |
The IP version to apply for the MongoDB connection. Values supported include:
If IPv6 is selected, the machine in which Monarch is installed should also support IPv6. |
Username |
A valid User ID required to log-on to the data source. |
Password |
A valid Password required to log-on to the data source. This password must match the User ID above. |
Connect |
Click this button after you have specified the URL, Username, and Password. You can select a Database and Collection after you have successfully logged-on. |
Database |
The name of the database to connect to. |
Collection |
The table to open. |
Table of Columns |
Displays the columns that are generated after you select the Generate Columns button. Once displayed, you can modify the following:
Displaying Array Values To display the values of an array type column, you need to do the following:
Generate Columns |
Instructs the application to query the database for the first few records and attempt to build a table schema from the available information. |
Add Column |
Adds a new column to the columns indicated in the JSON list box. The necessary information for each column added must be supplied. Ideally, the column is named the same as its JSON path for clarity and uniformity. |
Query Options |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query. If you want to define the query, enter the SELECT and/or EXEC statements to execute. Note: Currently, only Select and Exec statements are allowed. To minimize security risks and prevent SQL Injection attacks, the following are currently not allowed:
In cases you need to use a series of SQL statements with or without comments, we recommend you use stored procedures to contain these statements. The stored procedure can then be executed from the form. Refer to http://docs.mongodb.org/manual/tutorial/query-documents/ for more information on the Query Documents feature of the MongoDB Connection dialog. |
Preview Data |
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data. |
OK/CANCEL |
Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
