Setting Cylindrical Periodic Boundaries
Unlike Linear Periodic Boundaries which act on the Domain Bounding Box, Cylindrical Boundaries are manually set and exist within the domain.
Any particle exiting the boundary plane will enter the opposing plane and all forces, torques, positions, and velocities will be rotated by the difference in angle between the two planes. Select the
icon or select the box in the Settings menu to visualize the boundary.
You can define a cylindrical periodic boundary using the axis from a rotational kinematic or a vector based on a starting or end point.
Set the angle of the boundary as appropriate for the simulation. In the following image, the mixer has four blades at 90 degrees separation. In this case, the angle should be set to 90 degrees.
The boundary shows 20, 45, and 90 degrees.
Cylindrical Periodic Boundary Known Issues and Limitations
A Linear Rotational kinematic is required to setup the boundaries, even if the kinematic has a velocity magnitude of 0.
Plugin (API) factories are not supported with Cylindrical Boundary Conditions.
Simulator Auto Grid Size is not supported with Cylindrical Boundary Conditions.
Coupling Interface is not supported with Cylindrical Boundary Conditions.
GPU Solver is not supported with Cylindrical Boundary Conditions.
Cylindrical Boundaries are limited to a maximum 150 degree angle.
Cylindrical Boundaries cannot be used at the same time as Linear Boundaries.
Cylindrical Periodic Boundaries are not compatible with the bonded model.
Geometry must be rotationally periodic to use the boundary effectively. The two images below show a circle made from 10 edges and one made from 50 edges. If the geometry is not of a high-quality mesh then particles passing through boundaries will catch on non-periodic edges.
Low quality mesh (left), high quality mesh required for boundary condition (right)
- A central element (cylinder) is required at the mid-point of the boundary. At the center point of the boundary, it is possible for a particle to pass through the boundary and contact itself, which can lead to particle explosions. This can be prevented through definition of a geometry section at the center of the boundary.
