Creating a New Text Color Palette In a Workbook
The configuration pane for the Color variable changes depending on the column data type.
When a text column is added to the Color variable, the configuration pane displays the color associated with each categorical item, as specified with a default color palette (e.g., Twenty Eight Colors).
1. On the Text section, click the
New
icon.
The Next Text Palette dialog displays.
2. Enter the Title.
3. Select the Number of Colors in the drop-down list. Default is 28 colors.
The Other list is updated accordingly.
4. To set the colors:
· click the corresponding Color box to display the Color dialog to:
¨ select the color, or
¨ click
to
enter the values
for RGB
for HSL
for the Hex color code
· or enter the Hex color code
5. Click
The new text color palette is added in the list (e.g., Sixteen Colors). Note that it can be deleted.
