Neg
The sum of the negative values in the selection. If a value is positive or zero, the value n/a is returned.
Sample 1
Given a list of arbitrary numbers:
Arbitrary |
3 |
2 |
1 |
0 |
-1 |
-2 |
-3 |
0 |
0 |
0 |
A list of positive and negative numbers
1. Select which values are negative.
Arbitrary |
n/a |
n/a |
n/a |
n/a |
-1 |
-2 |
-3 |
n/a |
n/a |
n/a |
Negative numbers in the list
2. Add the negative values -1 + -2 + -3 = -6.
Sample 2
Given the following sample fields:
Number |
Arbitrary |
Negative Values |
Positive Values |
One |
Binary |
Currency |
Decimal |
1 |
3 |
-1 |
1 |
1 |
0 |
$1.00 |
1.01 |
2 |
2 |
-2 |
2 |
1 |
$10.00 |
2.02 |
3 |
1 |
-3 |
3 |
0 |
$100.00 |
3.03 |
4 |
0 |
-4 |
4 |
1 |
$1,000.00 |
4.04 |
5 |
-1 |
-5 |
5 |
0 |
$10,000.00 |
5.05 |
6 |
-2 |
-6 |
6 |
1 |
-$1.00 |
6.06 |
7 |
-3 |
-7 |
7 |
0 |
-$10.00 |
7.07 |
8 |
0 |
-8 |
8 |
-$100.00 |
8.08 |
9 |
0 |
-9 |
9 |
-$1,000.00 |
9.09 |
10 |
0 |
-10 |
0 |
$0.00 |
0.00 |
Sample fields.
The Neg value for each field in the table:
Number |
Arbitrary |
Negative Values |
Positive Values |
One |
Binary |
Currency |
Decimal |
n/a |
-6 |
-55 |
n/a |
n/a |
n/a |
$-1,111.00 |
n/a |
The results per field.
