PostExport Script
The PostExport tab is part of the Script Editor. Use this tab to add steps to further process the export file(s). Any script specified here will execute after any export actions take place and before any distributions occur.
The PostExport tab includes the following settings:
Script field: Displays the current post-export script.
Compile/Run: Compiles the script and if the script is compiled without errors runs it on the specified for testing location.
Insert Script: Allows you to quickly generate VB.NET script for frequently used tasks. Click to select the necessary options. For details, refer to Inserting a Script section.
Clear: Removes the scripts from the script field.
Locations for testing: Displays the location used for testing the script before deploying it.
