Exporting a Process
You can export a process on the Processes page.
The output of the export operation will be an XML file (or files) that can then be imported into some other Automator Installation.
To export a process
On the Navigation Tree, click Automator and select Standard Processes.
On the displayed page, select the Export Processes tab.
Select the process you want to export. Multiple selection is available.
Enable the Include process dependencies check box to export projects and project models from Server Library.
Specify the number of processes per file by selecting one of the following options:
One process per file if you want each Process to be exported to it's own XML file.
All processes in one file if you want the exported Processes to be exported into one XML file.
Click the Export button.
In the displayed dialog box, enter the name of the output archived file.
NOTE: If you selected the One process per file, the outputs will be named <process_name>_process.xml, located in the folder you have specified. If you selected All processes in one file, the output will use the name you specified, located in the folder you selected.
Click the OK button to export the process or Cancel to cancel exporting. A message box will inform you when the export operation has completed.
