Editing a Virtual Path
To edit a virtual path
On the Navigation Tree, click System Settings, and select Virtual Paths.
Click the name of the virtual path you want to edit or click anywhere on the row, and then click
The Virtual Path page appears. -
Make the necessary changes. For more information on how to change its items, see Adding a Virtual Path.
To save the changes, click Save.
The system saves the modified virtual path and displays the updated Virtual Paths page, if the operation is completed successfully. -
To reset the recent changes, click the Clear button.
To close the Virtual Path page without saving, click Cancel. Keep in mind that no changes will be saved.
