Cancelling a Job
Jobs may be cancelled at a number of stages prior to their completion. For example, you may want to cancel a job that has failed to run due to a missing process prerequisite if retries are enabled for the process and you are sure that the prerequisite will not be met in the near future.
To cancel a job
On the Navigation Tree, click Automator > Standard Processes and select Jobs.
On the Jobs page do one of the following:
Select the job you want to cancel, by clicking anywhere on the row, and then click
, or -
Click
at the end of the row
with the job you want to cancel.
