Connector Dialog for IBM Cloudant
Enter values into the dialog box to connect and fetch data from your IBM Cloudant data source.
Options
Field |
Description |
Cloudant Account or URL |
Enter one of the following:
Connect to a Specific Database |
Check this box if you are logging into a specific database. Then, enter the name of the database that you will be logging on to. Otherwise, you can leave this blank. |
Username |
A valid Username required to log-on to Cloudant. |
Password |
A valid Password required to log-on to Cloudant. This password must match the Username above. |
Login |
Click on this button to log-on to Cloudant. This assumes that the Account/URL, Database, Username, and Password have been entered correctly. A message box is displayed confirming if the login was successful. |
Database |
Select the database you will connect to. |
Source Type |
Select the Source Type. Corresponding sections will be enabled depending on the source type you select. |
Source Type = View |
If you select Source Type = View, configure how you wish documents to be returned from the view:
Source Type = Search Index |
If you select Source Type = Index, configure how you wish documents to be returned:
Preview Data |
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data. |
