Adding a Rekey Operator
Takes a stream data and changes its key. The new key can be any subset of fields from the stream.
NOTE |
This operator can never be applied to a table since tables require keys to be unique and therefore, you need to specify how multiple records with the same key should be aggregated.
1. In the Application page, click
and select Rekey
in
the Add Operator pane
The
Rekey node
icon displays in the Graph
panel, as well as the properties to be defined in the Operator
Settings panel, and the preview of the data in the Schema
panel.
The right (outbound) edge allows you to connect to the other operators.
2. In the Operator Settings panel, define or select the following required properties:
Property |
Description |
Node ID |
The ID of the rekey operator. |
Inputs |
The stream of records or input you will be subscribed to. |
Key |
The key column. Proceed to step 3. |
NOTE |
Node ID, Inputs, and Key properties are required.
3. In the Key section, click
to select the new key column in
the drop-down list box from the data source schema. Repeat to add
more.
You
can also delete a key column in the list by checking its box and clicking
The preview of the data (OUTPUT) is displayed in the Schema panel.
4. Save the changes.
