ksqlDB - Streaming Connector
The ksqlDB - Streaming connector allows executing ksqlDB push queries.
1. Select ksqlDB – Streaming from the Connectors panel. The ksqlDB - Streaming Settings panel displays.
2. Enter the Name of the ksqlDB
- Streaming data source, then click
3. Enter the following properties:
Property |
Description |
Server URL |
ksqlDB - Streaming host address. |
Username |
User Id that will be used to connect to ksqlDB - Streaming. |
Password |
Password that will be used to connect to ksqlDB - Streaming. |
4. Check the Collection box to enable and select either:
· Stream
Immutable and append-only collections which are useful for representing a series of historical facts. Adding multiple events with the same key allows these events to be appended to the end of the stream.
· Table
Mutable collections. Adding multiple events with the same key allows the table to only keep the value for the last key. This collection is helpful in modeling change over time and often used to represent aggregations.
5. Click
to
populate the drop-down list. Select the collection.
6. Enter an SQL-like query language into the Query box.
7. Check the From Beginning box to subscribe from the beginning to the latest messages.
If un-checked, you will only be subscribed to the latest messages.
8. Enter the Timeout. Default is 5 (in seconds).
9. Select either the dot (.) or comma (,) as the Decimal Separator.
10. Click
to the fetch the schema based
on the connection details. Consequently, the list of columns with
the data type found from inspecting the first ‘n’ rows of the input
data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
11. You can also opt to load or save a copy of the column definition.
12. Click
. A new
column entry displays. Enter or select the following properties:
Property |
Description |
Name |
The column name of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message should be processed. |
To
delete a column, check its
or all the column entries, check
the topmost
then click
13. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
14. For this section:
Refer to Define Real-Time Settings for more information.
15. Set the row limit of the data set.
16. Tap the Preview Selected Data Source slider to turn it on.
17. Click
to display the data preview.
