Locating the Source of a Record (Find in Report or Table)
You can locate the source of a record from any report using the Find in Report or Table option.
If you are in Report View, Find in Table shows where a particular line in a report is located in Table View.
If you are in Table View, Find in Report shows where a particular record in a table is located in Report View.
If you are in Summary View, Find in Table shows where a particular line in a report is located in Table View.
Locating the source of a record in a report
Move the cell pointer to any cell in the record in Table View.
On the Table View ribbon, select Find In Report. The detail line that was used to create the record is displayed and highlighted in the report.
Locating the row in the table that belongs to a detail line in a report
Move the cursor to any line in a report.
On the Report View. select Find In Table. The row created from the detail line selected is displayed and highlighted in the table.
Locating rows in the table that belong to a record in the summary
Move the cursor to any line in a summary.
On the Summary View. Select Find In Table. The detail line that was used to create the record is displayed and highlighted in the table.
