Freezing Panes in the Table Window
Monarch Classic’s freeze panes feature works like the same-named feature of MS-Excel; it freezes rows and columns to keep them on screen while scrolling remains active for the rest of the Table window. When you select the Freeze Panes command, Monarch Classic freezes all rows above the cell pointer and all columns to the left of the cell pointer.
Note: Monarch Classic does not record the names of the columns you have frozen. Instead, it records the number of columns that are frozen. A side effect of this method is that if you move a frozen column outside the frozen range, the range will expand to absorb one of the unfrozen columns, such that the number of frozen columns remains constant. Also, when you copy data that spans frozen and unfrozen columns, all of the selected data will be copied; not just the unfrozen columns.
Freezing one or more rows
Position the cell pointer immediately below the rows you want to freeze, in the left-most column.
On the Table View ribbon, select Freeze Panes > Freeze Panes.
Freezing one or more columns
Position the cell pointer immediately to the right of the columns you want to freeze, in the first row.
On the Table View ribbon, select Freeze Panes >Freeze Panes.
Freezing both rows and columns
Position the cell pointer immediately below the rows you want to freeze and immediately to the right of the columns you want to freeze.
Unfreezing rows and columns
