Editing a Filter Definition
You can easily edit a filter to change its name or expression.
Select Filters on the Table Design Ribbon. The Filters window displays.
Select a filter on the Filters selector. Depending on the type of filter you have selected, one of the following windows displays:
Edit the filter's properties as needed.
