Zooming In and Out in Summary View
You can zoom in or out in the Summary window by selecting a larger or smaller font size.
Zooming in or out using the zoom slider
Click the Zoom slider at the bottom-right corner of the screen:
Slide to the percentage zoom setting you want.
Zooming in or out using font size
Click the drop-down button on the font size box:
 on the Summary View Ribbon. The Monarch Classic displays the available font sizes for the selected font (from a minimum of 6 points to a maximum of 20 points). -
To zoom in (display larger characters but see less data on screen), select a larger font size. To zoom out (view more data on screen), select a smaller font size.
Note: The available font sizes may vary depending upon the font selected. If the size you want is not available, use the Toolbar’s Font selection box to select another font.
Zooming in and out in the Summary window
Click the drop-down button on the font size box of the Summary View ribbon. Monarch Classic displays the available font sizes for the selected font (from a minimum of 6 points to a maximum of 20 points).
Note: You can also select Zoom to Fit on the Summary View ribbon.
To display larger characters but see less data on screen (zoom in), select a larger font size. To view more data on screen (zoom out), select a smaller font size. The available font sizes may vary depending upon the font selected. If the size you want is not available, use the font drop-down list to select another font.
Note: Although Monarch Classic allows only fixed-pitch fonts in the Report window, proportional-pitch fonts can be used in the Table and Summary windows.
