Using Aggregations
Monarch Classic includes aggregations which you can use to perform arithmetic functions on the values of a measure in a summary. The following types of aggregations are available in the Edit Measure Expression dialog:
Cumulative aggregations
       Aggregation  |
       Description  |
       Cum()  |
       Returns the cumulative sum.  |
       CumCount(*)  |
       Returns the cumulative row count.  |
       CumCountPct(*)  |
       Returns the cumulative row count as a percentage of the total rows.  |
       CumPct()  |
       Returns the cumulative sum as a percentage of the total sum.  |
Count aggregations
       Aggregation  |
       Description  |
       Count(*)  |
       Returns the count of rows (or non-null values of the field) within the group.  |
       CountPct(*)  |
       Returns the group row count as a percentage of the total rows.  |
       CountSubPct(*)  |
       Returns the group row count as a percentage of the row count in the next larger group.  |
       CumCount(*)  |
       CumCountPct(*)  |
Percentage aggregations
       Aggregation  |
       Description  |
       CountPct(*)  |
       CountSubPct(*)  |
       CumCountPct(*)  |
       CumPct()  |
       Pct()  |
       Returns the group sum as a percentage of the total sum.  |
       SubPct()  |
       Returns the group sum as a percentage of the group sum of the next larger group.  |
Statistical aggregations
       Aggregation  |
       Description  |
       Avg()  |
       Returns the average value of the field within the group.  |
       Max()  |
       Returns the maximum value of the field within the group.  |
       Min()  |
       Returns the minimum value of the field within the group.  |
       Stdev()  |
       Returns the standard deviation of the field values within the group.  |
       StdevP()  |
       Returns the standard deviation (with respect to the population) of the field values within the group.  |
       Sum()  |
       Returns the sum of the field values in the group.  |
       Var()  |
       Returns the variance of the field values within the group.  |
       VarP()  |
       Returns the variance (with respect to the population) of the field values within the group.  |
Special aggregations
       Aggregation  |
       Description  |
       Unique()  |
       Returns the unique value of the field if there is a unique value, otherwise returns null.  |
