Time Intervals Options
This window allows you to set time intervals settings, namely the characteristics of the fiscal year, fiscal weeks, fiscal periods and the formatting masks used when displaying them in Summaries. See Working with Time Intervals for more information.
To access this window select Options from the Home ribbon, then select Time Intervals from the Options Window ribbon.
Fiscal Year
Field |
Description |
12 calendar months. |
Specifies that the fiscal year consists of 12 calendar months, |
The year starts on the first day of [month]. |
Select the month, the first day of which begins the new fiscal year. |
52-53 fiscal weeks. |
Specifies that the fiscal year consists of 52-53 fiscal weeks. When you click on this option additional options below are enabled. |
Based on the reference date [month and day]] and each fiscal week starting on [day of week] the year is defined to start on [options] |
Select the appropriate values to define the start of the fiscal year. |
The year is divided into four 13-week quarters. |
Select to divide the year into four 13-week quarters, then pick one of the following:
For 53 week years the extra week is in |
If the year has 53 weeks, use this to specify where to put the extra week.
The year is divided into thirteen 4-week periods. |
Select to specify that the week is divided into thirteen 4-week periods. |
Sample values |
Displays sample fiscal years based on the settings you've specified above. |
Calendar Week
Field |
Description |
The first full week starts on the first [day of week] on or after January 1. |
Specifies that the first full week of the year starts on the first day of the week on or after January 1. By selecting values from the drop-downs, you need to specify:
Week 1 always starts on January 1 |
Select this option if Week 1 always starts on January 1. |
Sample values |
Displays samples based on the information you have provided above. |
formatting
Field |
Description |
Interval |
Lists the names of the time intervals available.
Formatting Mask
Displays the formatting mask applied to the adjacent interval. To edit the formatting mask, double-click on the desired time interval, or select an interval and press the Edit Formatting Mask button |
Sample Value
Shows the effect of the formatting masks on today’s date, using the Calendar Week and Fiscal Year setting defined in the Registry if no model is loaded or saved, or the Calendar Week and Fiscal Year setting defined in the model if one is open. To change the date that the sample value is based on, adjust the sample date calendar control accordingly. This is located immediately below the table containing the time intervals on the right hand side. |
Description |
Displays a description of each time interval.
GENERAL
Button |
Description |
Make these the default settings |
Saves the current settings in the Registry as the defaults for future Monarch Classic sessions. Note: When closing the current model you will be prompted to save the model changes. You must select Yes to save the tab settings as the defaults. If you choose not to save the model changes, the tab settings will not be saved as the defaults. |
Restore from default settings |
Restores the settings to the default values previously stored in the Registry. |
