Summary Definition Window
Use this window to create a new summary definition or to edit an existing summary definition.
To access this window, select Definition from the Summary Design ribbon.
Options
       Field  |
       Description  |
       Name  |
       Enter a name for this Summary. This name will identify the Summary and will display on the list of Summaries on the Summaries Menu.  |
       Apply Filter  |
       Select a filter to apply to the table before Monarch Classic builds the Summary. This way you can create a summary using only a subset of data in the table.  |
       Default style:
       Displays the color style of the summary. You can edit the color style via the Color Properties dialog by clicking the adjacent Edit button:
 Note: The default style is applied to all of the summary’s cells. If you specify a title row style or total line style – or if you specify font and background colors for key, item or measure fields – these settings will override the default style ones.  |
       Title row style:  |
       Displays the color style of the summary’s title row. You can edit the color style via the Color Properties dialog by clicking the adjacent Edit button:
       Total Line options  |
       Insert total line  |
       Select to insert a total line at the bottom of the summary. The total line displays totals for all measures in the summary.  |
       Label  |
       Enter the name you want to apply to the summary’s total line.  |
       Style  |
       Displays the color style of the summary’s total label. You can edit the color style via the Color Properties dialog by clicking the adjacent Edit button:
       Insert n blank line(s) before total line  |
       Use to specify the desired number of blank lines you want to insert before the total line.  |
       Apply label style to measure columns  |
       Click to make all measures columns have the same style as the Total Label.  |
       Comment  |
       Enter comments or notes about this summary.  |
