Remove Negative Signs (Abs)
Returns the absolute value of the value of a column.
INPUT/Output DATA TYPE
Input |
Output |
numeric |
numeric |
example
In this example, Amount is the original column. AmountAbs is the result showing the absolute values of Amount.
