Remove Leading & Trailing Spaces (Trim)
Trims all leading and trailing spaces from a string.
INPUT/Output DATA TYPE
Input |
Output |
text |
text |
example
In this example, the Idiom is the original column and Idiom - Clean shows the new values, with the leading and trailing spaces removed.
