Open Web File Dialog
Use this dialog to define the connection to your Web Server or FTP site.
This dialog displays when you select Web File as your data source from the Open Database dialog.
Options
       Field  |
       Description  |
       Address  |
       Enter the URL or Web Server Address. This address must include http:// or ftp:// Example If you were using an FTP site the address could be: ftp://user.mysite.com/ Note: If you have entered addresses in previous open web file operations, you can use the drop-down button to display a list of existing addresses.  |
       Connect  |
       Connect to the Address specified, using credentials you have entered in the Security Options dialog.  |
       Cancel  |
       Cancels the open web files operation and closes this dialog box.  |
       Help  |
       Displays this help topic.  |
