Application Settings
Select the Settings icon to modify application settings:
This displays a dialog box that will allow you to set the following:
Options
Option |
Description |
General |
Check on the box if you want all table names to be prefixed by the document name. |
Conversion |
These settings affect how information from text-based data sources is interpreted and converted to either the numeric or date/time format.
