Input Field Properties Window
Use this window to view or edit the properties of an input field (i.e. a non-calculated field that is extracted by a template). To access this window, select Input Fields from the Table Design ribbon.
To view or edit the properties of all fields, use the Field List window by selecting Field List from the Table Design ribbon.
General tab
Field
Name
Accepts a name for the field. If you have not named a field it is indicated by the prefix "eg_" and the sample data from the first record encountered. Field names may be up to 62 characters in length and may contain uppercase and lowercase characters, spaces and punctuation except for period (.), exclamation point (!), accent grave (`) and brackets ([ ]). Names may begin with any character, except for an underscore or space. If a name is entered with leading spaces, the name is accepted but the leading spaces are ignored.
Note
If you elect to enforce DBF field naming rules, field names must adhere to the dBASE III field naming convention:
Names may be up to ten characters long and may contain any letter or number and the underscore character (_).
The first character must be a letter.
Spaces and punctuation are not allowed.
Displays the field’s type. The drop-down list contains all available field types: character, date/time, numeric, and memo. Monarch Classic initially sets the field type according to the data it finds in the field.
Decimals
Accepts a value representing the number of decimal places of accuracy that will be calculated for a numeric field. (This value is grayed for character, date, and memo fields.) Note that the data length value must be large enough to accommodate both the integer portion and the decimal portion of the largest number that the calculated field expression is likely to produce. Monarch Classic rounds all values in the field to accommodate the specified number of decimal places.
Displays the selected format for the field. The drop-down list contains all available formats for the field type.
For character fields, the only format available is General.
For numeric fields, the formats are:
General
Thousands
Currency
Percentage
Time Span
For Date/Time fields, the formats are:
General
Short Date
Long Date
Short Date and Time
Long Data and Time
Time
Japanese Date (This format is available only if Fullwidth Character Mode is On. Turn Fullwidth Character Mode on or off from the Language Tab of the Input Options window )
Japanese Era Date (This format is available only if Fullwidth Character Mode is On. Turn Fullwidth Character Mode on or off from Language Tab of the Input Options window )
For memo fields, the only format available is General.
For more information on field formats see Changing a field's type.
Display Width
The display width refers to the width of the field (or column) on screen in the Table window. If the display width of a numeric field is set to less than the width of the field values, the field values display as pound signs (####). For character fields and date fields, field values are truncated on screen. In all cases, the actual data in the field remains unaffected; the display width setting affects only the way that the data appears on screen.
Alignment
Displays the current alignment setting of each field. Text fields are by default left aligned, while numeric fields are right aligned. Alignment settings carry over to the summary.
Hidden
Select to hide the field from view. Note: Hidden fields are not available for export or copy operations. They can be restored (i.e., re-displayed) by un-selecting this box.
Template tab
Field
Template Width
Displays a field’s template width (the number of characters extracted from a report). This value is blank for calculated fields and for fields imported from an external database. You can modify the template width by clicking on its cell and typing a new value. You should use caution, however, when changing this value, as it has implications for how data is extracted from a report. Typically, you would change this value to adjust the width of a field to match a change in the structure of a report. For example, when dealing with Y2K, an IT department might have modified the structure of a report to accommodate years expressed in four digit format. This change would cause date fields in a report to grow by two characters, so you might need to increase the template width to accommodate this change.
Verify (non-calculated fields only)
Displays, and allows the specifying of, the current field verification settings. The selected settings are used when verifying field boundaries.
Left side: Select to verify the field’s left boundary.
Right side: Select to verify the field’s right boundary.
Type: Select to verify the field’s type.
Empty Cells
Many reports are designed so that duplicate field values do not repeat down the page. When Monarch Classic extracts the data from the report and builds a database table, it does not automatically duplicate these values, leaving empty cells throughout the field.
Copy value from previous record (non-calculated fields only): Select this option to copy the appropriate values into the empty cells.
Redaction
Select the redaction method to be used:
X-over text: All text characters are replaced with x. You can only apply this method to fields of type character.
X-over non-blanks: All characters except blanks are replaced with x. You can only apply this method to fields of type character.
X-over digits: All numeric characters are replaced by x. You can only apply this method to fields of type character.
X-over digits except last 4: All numeric characters except the last 4 are replaced by x. You can only apply this method to fields of type character.
Replace with blanks: All characters are replaced with blanks. You can only apply this method to fields of type character.
Consistent alias text: Replaces all instances of a field value with the same set of text characters. You can only apply this method to fields of type character.
Consistent alias digits: Replaces all instances of a field value with the same set of text characters.
Pseudo bank card number: Numeric characters are replaced with random digits, but adjusted so that the resulting number has an incorrect Luhn algorithm check digit.
Pseudo SSN: Numeric characters are replaced with random digits, but adjusted so that the resulting SSN is not valid.
Pseudo NHS Number: Numeric digits are replaced with random digits, but adjusted so that the resulting NHS number is not valid.
Refer to Redacting Field Values for examples and additional information.
Advanced tab
Use the Advanced tab to capture multiple line fields. A multiple line field may have a fixed number of lines or a variable number of lines. Select one of the Start Field On options to indicate the location of the first line of the field, then select one of the End Field On options to indicate the location of the last line of the field.
Field
Start Field On options:
Select one of the following options to indicate where the selected field begins:
Line Number: Select this option to indicate that the first line of the field begins at an absolute offset from the top of the template. The line number represented by this setting is determined by the position of the field highlight in the template sample. For example, if you highlighted the field on the second line of the template sample, this option would be represented as Line Number 2.
String [string] anywhere In Previous Line: Indicates that the defined field will exist only if the specified string is found anywhere on the previous line, so the field will start on the following line from where the string is found. This option is typically used to assist in the trapping of HTML data.
Preceding String [string] in current line: Select this option to indicate that the first line of the field begins immediately to the right of a string, such as a label. Enter the string in the adjacent box. The maximum length of the string is n-1 where n is the column starting position of the field. For example, if the field starts in column 15 you may enter a string of up to 14 characters (i.e., the entire search string must fit to the left of the field). This option is typically used to locate a field based upon the presence of a label to its left.
After Last Defined Field in Template: Select this option to indicate that the first line of the field begins two lines below the last line of a multiple line field which is also extracted by the template. This option can be used to capture a field that falls immediately after a variable line field, in which case the starting position of the second field may vary relative to the top of the template but falls at an absolute offset relative to the end of a variable line field. This option can be used to capture a multiple line field or a normal [single line] field. To capture a normal field, select the "Line Count: 1" End Field On option.
End Field On options:
Select one of the following options to indicate the height of the field:
Line Count: Select this option to terminate the field after a fixed number of lines. This option should be used whenever all instances of the field have the same number of lines. Use the spin box to indicate the field's height, in lines.
Nonblank Preceding String of n Characters: Select this option to terminate the field when a line is encountered that contains a nonblank string to the left of the field. The maximum length of the string is n-1 where n is the column starting position of the field. For example, if the field starts in column 15 you may specify up to 14 as the length of the nonblank string (i.e., the entire string must fit to the left of the field). This option is typically used to terminate a field based upon the presence of a subsequent field or field label that appears below and to its left. Note: Use this option only if the number of lines in each instance of the field varies. If the field always contains the same number of lines, use the Line Count option, described above.
Blank Field Values: Select this option to terminate the field when a blank line or series of blank lines is encountered. It is important to note that Monarch Classic does not require the entire line to be blank, only the column positions occupied by the field. Use the spin box to indicate the number of blank field values required to terminate the field. Note: Use this option only if the number of lines in each instance of the field varies. If the field always contains the same number of lines, use the Line Count option, described above.
End of Left Justification: Select this option to terminate the field when Monarch Classic encounters a line with a blank in the first column position of the field or any nonblank character in the column immediately preceding the field. Either of these conditions indicate that left justification has ended. This option is useful for capturing left aligned text blocks. However, if the text block contains a blank line, such as that found between paragraphs, Monarch Classic will consider the blank line an end to left justification and will therefore terminate the field. For multiple paragraph blocks, use either the Nonblank Preceding String option, the Blank Fields option or the Trap By Any Other Template option. Note: Use this option only if the number of lines in each instance of the field varies. If the field always contains the same number of lines, use the Line Count option, described above.
Any Template Hit: Select this option to terminate the field when Monarch Classic encounters another template, including another instance of this template. The field will also be terminated if an HTML markup line is encountered. Note that a multiple line field will not terminate if it encounters a Postal line template. In this case, the Postal line template is ignored and the multiple line field continues. The Postal line template will not be affected (the address fields will be extracted both by the Postal line template and the multiple line field).
Monarch Classic will also terminate a multiple line field after it extends two pages. The field will be terminated on the second page where the page break character (character code 12) is encountered. This prevents a field from continuing without end if the selected End Field On action is not appropriate to end the field.
Note: The Any Template Hit behavior is always enforced by Monarch Classic, even when the Any Template Hit option is not selected. Select this option only when none of the other options would apply.
Using a dummy template to terminate a multiple line field - If none of the other End Field On options can be used to terminate a multiple line field and you don't have an appropriate template already defined that can be used to terminate the field, consider creating a dummy template specifically for this purpose. By creating a template, you have available to you all of Monarch Classic's sophisticated trapping techniques.
