Filter
A set of conditions used to limit the records available for use in Monarch Classic. For example, the filter LASTNAME="Smith" or "smith" (note that comparisons are not case sensitive) will display only those records with a value of "Smith" in the LASTNAME field. See the Overview: Filters topic for more information.
