Function: Int
Returns the integer portion of a number.
Int(number)
Arguments
number can be a constant, a numeric field, an expression that results in a number or a function that returns a number.
Return value
This function returns a number.
Calculated field example
If the Price field contained the value 10.99, the following calculated field expression would return the number 10 (the integer portion of the field's value): Int(Price)
Filter/Find example
Records with a Price field value of 10.99, 10.02 or 10 can be selected or found using the expression: Int(Price)=10
