Function: FiscalQtr
Returns the number (1-4) of the fiscal quarter in which the given date falls.
FiscalQtr(date).
Arguments
Date may be any valid date in the range 1/1/1601-12/31/2400
Return Value
This function returns a number (1-4).
Calculated field example
The following expression will display 2 for a Ship Date field containing 4/1/2008: FiscalQtr([Ship Date])
Filter/find example
Records with a ship date that falls within the first fiscal quarter can be selected or found using the following expression: FiscalQtr([Ship Date])=1
Note: The example above assumes that the following time intervals settings have been specified via the Time Intervals wizard:
The fiscal year consists of 12 calendar months starting on January 1.
The fiscal week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
The calendar week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
