FiscalPeriod Function
Returns the number (1-13) of the fiscal period in which the given date falls.
FiscalPeriod(date).
Arguments
Date may be any valid date in the range 1/1/1601-12/31/2400.
Return Value
This functions returns a number (1-13), representing the quarter in which date falls.
Calculated field example
The following expression would return 3 for a Ship Date field containing 3/1/2008: FiscalPeriod([Ship Date])
Filter/find example
Records with ship dates that fall within fiscal periods 1 through 7 can be found with the following expression: FiscalPeriod([Ship Date])<=7
Note: The example above assumes that the following time intervals settings have been specified via the Time Intervals wizard:
The fiscal year consists of 12 calendar months starting on January 1.
The fiscal week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
The calendar week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
