Function: Exp
Returns e – the base of natural logarithms – raised to the specified power. Note: The constant e approximately equals 2.718282.
Exp(number)
Arguments
number can be a constant, a numeric field, an expression that results in a number, or a function that returns a number.
Return value
This function returns a number.
Calculated field example
The following calculated field expression returns the value of e calculated to 7 decimal places (2.7182818): Exp(1)
