Edit Report Colors Dialog
Use this dialog to assign colors to templates in the Report window.
To access this dialog, select Report Colors from the Report Design ribbon.
options
Field
Template Coloring options
None: Select if you don't want to apply colors to templates in the Report window. Note: Selecting this option will render the templates invisible.
Gray background: Select to highlight templates in the Report window with a gray background.
Custom background for each template type: Select if you want to create a custom background color for each template type, then click the adjacent Edit buttons and use the Color dialog that displays to specify the desired color.
Page Header: Click the adjacent Edit button to specify a custom color for the page header template
Append: Click the adjacent Edit button to specify a custom color for the append template(s).
Detail: Click the adjacent Edit button to specify a custom color for the detail template.
Group Footer: Click the adjacent Edit button to specify a custom color for the footer template(s).
Show Greenbar
Select to display the reports with the greenbar feature.
OK
Saves the current settings and closes the dialog.
Cancel
Cancels any changes you have made to the settings and closes the dialog.
Help
Displays this help topic.
