Create Export Dialog
This dialog allows you to create an export definition.
To access this dialog box, select Create Export on the Export View ribbon.
Options
       Field  |
       Description  |
       File Name  |
       Enter the file name that will be used for export output.  |
       Source View  |
       Use this selector to select the source of the export.  |
       Export File Type
       Specify the export file type. Additional options need to be defined depending on the file type that you select.  |
       Run this Export  |
       Select this button if you want to immediately run the export after defining it.  |
       Add to Project  |
       Click this button if you want the export to be saved with the Project.  |
       Advance Options  |
       Select this button to define additional options. Options vary depending on the Export file type.  |
       When output files exist options  |
       Provides options for when a file of the specified name and type already exists in the export location. Select one of the following options:
