Connector Dialog for Google Ads
Enter values into the dialog box to connect and fetch data from your Google Ads data source.
Options
Field |
Description |
Developer Token |
The developer token of the Ads account. |
Client Customer ID |
The client customer ID of the Ads account. |
Schema |
The version of schema to use to get Google Ads data. Notes:
Important: The AdWords API is no longer available for new users. Developers accepting the Terms and Conditions when applying for a new developer token after April 28, 2021 are only given access to the Google Ads API. Using the token for AdWords API calls results in a QuotaCheckError.INVALID_TOKEN_HEADER error, with the message that new developers must use the Google Ads API.
IP Version |
Select from the drop-down if you need to force the IP version to connect to your data source. Available values are:
The default is Autodetect, to let the system automatically select the correct IP version. |
Other Connection Options |
Connection options required to connect to the data source. If you need multiple string connection options, separate these by a semi-colon. However, you can only enter up to a maximum of 512 characters into this text box. Available options and valid values are discussed here. |
Reset Connection |
Check to reset the connection. |
Tables and Views Section |
Allows you to load, and then select, the tables from your database by manually selecting from a list. To load tables and views via search and select:
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column: Check the boxes beside the columns you want to use. If you want to use all columns check the Column box on the header.
To aggregate columns:
If the data returned are to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column. The following aggregation methods are possible for each data type:
To filter columns:
If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box. Note that some data sources require case-sensitive filter values. Refer to this list to check which data sources have case-sensitive filters. To load tables and views using an SQL Query, select the Query tab |
Query |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query. If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute. Notes
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
