The Browse for File Dialog
A standard Browse for FIle dialog allows you to select a source file on the cloud.
Select a Container.
Find the folder and then source you want to open. You may need to drill down several folders before you find your data source
Select the source and click OK.
Note
If you are trying to browse for an Azure Data Lake or Amazon S3 Source, you need to first set the access credentials in the Server tab of Application Settings:
