Altair® Panopticon
Using Altair Units License in the Panopticon Streams
Before using the Altair Units license type in the Panopticon Streams, it is required to configure certain properties in the Streams.properties file  located in the AppData  folder or c:\streamsserverdata:
Property
Service authentication level
Attribute
authentication.required
The property that will make the authentication required. It will force the user to login in order to use any of the services provided by the server. Must be set to true.
Default Value
true
Property
Licensing
Attribute
license.hwu.operating.system
The operating system where the Panopticon Streams Server is installed. Possible values are: WIN_X86, WIN_X64, MAC, LINUX_X64, or LINUX_ARM64
NOTE: If the Java bitness (e.g., 32-bit) is different from the operating system (e.g., 64-bit), it is recommended to add the Java bitness in this property (e.g., WIN_X86).
Default Value
Property
Licensing
Attribute
license.hwu.uri
The path where the License Server is running e.g., 6200@191.255.255.0 where the syntax is PORTNUMBER@HOST. If multiple servers are used, they should be separated by ‘;’.
NOTES:
Multiple License Servers are not supported when the Panopticon Streams Server is on a Linux machine.
If value is not set in the Streams.properties, the environment variable ALTAIR_LICENSE_PATH serves as the backup path and will be used
Default Value
Property
Licensing
Attribute
license.hwu.version
Value must match the license version found in the Altair Units license file.
Default Value
19.0
Property
Licensing
Attribute
license.mode
The license mode. Possible values are: FILE or HWU. Must be set to HWU.
Default Value
FILE
For example:
authentication.required=true
license.hwu.operating.system=WIN_X64
license.hwu.uri=6200@192.168.5.51;6200@192.168.5.52
license.hwu.version=19.0
license.mode=HWU
   NOTE
·         The Panopticon Streams Server supports different user roles which check out different numbers of Altair Units.
Role
Altair Units License Draw
Designer
21
Administrator
2
·         Logging in to both the Panopticon Visualization Server and Panopticon Streams Server with the same username levels the unit draw. A total of 21 units are drawn even if the user logs in to both servers.
·         Running applications are leveled towards the user who started the application.
For example, a user can run 10 Streams applications while also being logged in as an Administrator and the total unit draw will only be 21. For the 11th application the total draw will be 22. After this, units will increase by 2 for each additional application. For the 12th application, the total draw will be 24.
