Altair® Panopticon
Bson-Wise Array Expansion
MongoDB’s BSON document structure can store array data types. In order to interpret that data for Designer (Desktop), the user has to decide how they want those multi-value fields to be displayed.
Bson-wise array expansion allows parsing of all the fields of a nested hierarchy in a sub document of a JSON array. During data retrieval, the column value is converted to JSON, and nested columns are flattened based on a JSON parser logic.
To use the Bson-wise expansion feature, select Bson-Expanded Array in the Structure drop-down box.
