Starting an Application on the Application Page
1. On the Applications tab, click an application link to open and display it on the Application page.
2. Click
to run the application.
This
also enables the
icon and generates the
stream topics and
the data
producer.
3. You can also perform the following:
· click on a node in the Graph
panel and
to
display its Operator Settings as well as the preview of the data (OUTPUT)
in the Schema panel
· click
to
display the node’s Metrics as well as the preview of the data (OUTPUT)
in the Schema panel
· select all the nodes and click
to display all of their
throughput values (total and current message rates) in the Metrics
panel.
· select an input or output node and click
to
display the data preview.
You can also click:
to copy the data
to a clipboard.
to pause the update.
To start the update, click
